My ST3 generator head has been in service about 12 hours, running a 230VAC 1/2HP submersible well pump. It was running fine this morning. Alas, when I went to start it up again this afternoon for a few hours, the output voltage is only 115VAC (no load). This puts my off grid shop/home site grading project at a standstill.
I checked all the connections, brushes, etc. Everything looks fine. I had no oscilliscope at my remote property, just a VOM.
The half voltage output seemed like a possible field coil diode bridge failure, so I took apart the stock bridge and checked each diode. Alas, they check out OK, but one had a cold solder/loose connection to the heat sink after I moved the wire so I will attempt to resolder it this PM. I don't have confidence that this was loose before I moved the wire, though it was a bad solder joint.
Any suggestions for what might be wrong and/or where I could get a replacement diode bridge quick?
I have a battery powered oscilliscope I can bring out tomorrow.
Thanks,
Bruce M
