Hi Jack,
Then there's the mass of the flywheel to consider. A high speed diesel like your MP won't have as heavy a flywheel as a thumper will, so funny things might happen during starting and maybe some sort of kickback is possible, but I've never heard of it before. I suppose if the ignition were advanced a bit too far that might be more likely, so maybe I should have said "properly timed" diesels don't kick back. But then, an improperly timed diesel won't run well anyway, so that's an anomaly anyway.
I've had my engine bounce off compression several times when I wasn't really paying attention, but it was the bounce was never powered by ignition. It gets your attention, though, doesn't it?
Halfnuts
