Hey guys,
Another small update on what's happening with the green monster.... Since new gasket is installed with the higher c ratio, lots less smoke when running a 30w or so fuel. I think I have discovered what was causing intermittent smoking and carboning over the last little while and thought it might be worth the mention...
When I process fuel, I feed it into a 200l holding drum, drawing off the bottom quarter or so. Up until recently, I found this to work quite well. Now however, it seems with the warmer weather we are having, there is some heavier oil settling to the bottom. When filling of late, this heavier oil(estimated at 45w plus) has been causing a bit of a problem... knock it down with a 4 or up to even 8 to 1 dino mix and it runs way awesome....
I have also now installed an auto switch over for the mains. It consists of one contactor powered directly by the generator, disengaging a second contactor powered by the mains. It works quite well, so much so that when the gen head stopped working today(more on that later), the switch back to utility power wasn't even noticed... not even by a ps3 that was online downloading some rather large game update... There is one small problem that I have to overcome the contactor on the mains side is a bit like me... slow, old and lazy... it, on the odd occasion, takes a spilt second too long to drop out and causes the gen head to go head to head with the mains... No biggie, but I don't like it as it trips the trip switch on the panel... I will have to get a better contactor or try and sort out some form of delay without using a "bought" one... No matter... I will find a way.... suggestions welcomed!
The gen head finally tossed its cookies, there is one wire on the ac brushes that had chafed through to earth and welded itself there... No matter, I just swopped the L and N lines over as a temp measure to keep going(N and E are linked in the panels anyway), well .... eventually it went open circuit today... The faulty wire was snipped off and a bypass wire installed externally.... Working better than ever, looks like this new "temp" fix might just end up to be a permanent one...
They say that bad luck comes in threes, well, I had my set today... first the contactor laziness, then the busted brush wire, and finally a broken wire on the cooling fan... Luckily I installed a temprorary temperature controller on the head outlet yesterday... my mission is to control and vary coolant temperatures by adjusting when the fan comes on to minimise or try to, control head temps a bit to get the cleanest burn on varying fuels.... well, it looks like the temp controller might just become semi permanent once the temp experiments are done, it will be wired to an over temp siren to let me know when and if things go awry....
One good thing did come of it though... I established that there is more than enough cooling sans fan to keep the heat down if the engine is running unloaded as it did for quite a while today.... No Gen, means no cooling fan and no instrumentation working either.... The radiator is thermo syphon, so that won't fail....
Anyways, again I ramble on,,,,
Keep it spinning...
Regds
Ed
