I am reconditioning a 10 year old GM90 listeroid.
The work I did included:
Installed new rings after crosshatching the cylinder
Installed new head gasket
Lapped both valves
Installed new fuel pump and injector
I checked the cam timing, it is still exactly correct.
I adjusted the spill injector timing, though note I found 3 different methods. Those that required removal of the pump inner check valve and spring, and turning the flywheel before and after the 20 BTDC inject location, don't make sense. They indicate to turn the flywheel backwards till the flow starts, then forward till it stops. When in my case, the opposite happens, in reverse it stops, and starts when rotating forward to the 20 BTDC mark. Seems to me those instructions are written backwards?
I used the other method, leaving the pump internals installed, watching for begin of flow at the top of the pump delivery hole, matching it to the 20 degree position. Makes sense right?
At any rate, I only ever get a puff of white or gray smoke and a bump. The fuel was properly bled, I get the proper injector squeak, and the engine has super (seems to me) compression, it's almost impossible to turn without the decompression lever in place. The ignition bump does not aid the engine in starting, it's jsut a resistance bump each time.
Any thoughts what this might be?
