Author Topic: offset idler bolt  (Read 3125 times)
islander
offset idler bolt
« on: April 03, 2015, 08:20:02 PM »
Hello
I'm looking for a 0.040 offset idler bolt for lister C/S. For use on a powerline 12/1
If you make them, if you have one, please send a personal message to me
I've got paypal.
thanks
Perri
Re: offset idler bolt
« Reply #1 on: April 03, 2015, 10:49:55 PM »
I see you're are a newbie such as myself. What is an offset bolt? Be patient, you'll find this forum slow but very useful.
« Reply #2 on: April 03, 2015, 11:46:30 PM »
If you use the site "Search" function above you will be able to find lots of threads (posts) regarding the use of offset idler bolts. The purpose of that modification is to tighten up loose fitting valve train gearing. It basically just moves the idler gear center closer to the crankshaft pinion and cam gear for a better fit. You would want to measure clearance (gear lash) carefully before making a decision to make such a change in your engine.
