I ran my Vidhata for about a half hour again today. I mentioned in my previous post that I heard a squealing sound and thought my generator bearings might be dry, so I shot some additional grease in the fittings. Well, that squeal showed up again today and this time I used the old mechanic's trick of placing a short length of garden hose to my ear and snooping around the whole unit trying to isolate the noise. To my surprise, it was coming from the crankshaft where it emerges from the crank case on the injector pump side of the engine. It was sort of a squealing, whistling sound and not the bearing, so it almost had to be a dry seal. This engine has probably a grand total of one hour's running time so it's still "new" and I have no idea what is used for seals.....are they neoprene? Leather? Whale blubber?
I shut the engine down and used a long spout oil can to dribble oil around the joint of the crankshaft and case, rolling the flywheel around to distribute it. When I started it up again the squeal was gone and didn't return in fifteen minutes of additional running. I'll monitor it carefully.
I also noticed that the stock governor spring was causing hunting, so I changed it BACK to the Home Depot spring that I thought was giving me over speeding yesterday. To my delight the voltage is much more stable and the engine responds better to placing/removing loads. I kept a close eye on things and there were no problems, so maybe it was something I did and blamed it on the spring. Further running will tell the tale.
I guess I'd better get busy and get some pictures on here soon before everyone thinks I'm a "teller of tall tales". So far though, I'm a pretty happy camper.
I'm tired.........time for a cup o' coffee and some feet up time!
