Author Topic: CS 6/1 Fuel consumption  (Read 6977 times)
Gippslander
« on: January 03, 2015, 12:32:23 AM »
Hi
Just wondering about the fuel consumption for a 6/1 driving a 3kW ST head ?
Mike
http://listerengine.com/smf/index.php?topic=3790.0
PS  I found this
« Last Edit: January 03, 2015, 12:37:53 AM by Gippslander »
Tom
  • Green power is good.
Re: CS 6/1 Fuel consumption
« Reply #1 on: January 03, 2015, 12:58:22 AM »
The official fuel usage is .11 gal per kw per hour. My 6/1 is run at about 3kw and uses about 1/3 gal of fuel an hour.
Tom
« Reply #2 on: January 03, 2015, 02:14:53 AM »
My 6/1 & ST5, at 1,400 ft, running around 1740wh, gave me:
227 Hours YEAR    395,405 Wh    59.5 Gallons   6,645 Wh per gallon   0.262 gl / hr
pump diesel w/10% bio-diesel or some 2 stroke oil for the pump lube
Well, look at that, While I try to keep it loaded up to about 2500w, when "stuff" happens, and the batteries fill up, or I was
still dialing in the charger, I put a lot of lightly loaded hours on it.  I don't notice it using oil,
buickanddeere
« Reply #3 on: January 07, 2015, 12:33:23 AM »
 A natural aspirated diesel will run 12-15 HP per gallon per hour at 100% load. A typical PHW2 Petter would do about 14.75 HP per gallon per hour iirc. Seen a recent Nebraska  test on a Tier IV emission John Deere that was making 18.95 HP per gallon per hour iirc.
