Hugh,
Are you also using the 240vac output on your setup? What type of generator head are you dealing with? There are many viable variations in design for what you propose to instrument. Most of this is quite simple and logical.
1.) Your Frequency in Hz can be read hot-to-neutral at whatever voltage (and thus connection choice) your meter is designed for, and from any of your output windings as they will all read identical in Hz. Just match voltage range to the meter rating. It sounds like you have exactly the right idea for a 120volt meter except it should NOT be connected with the Ammeter circuits. I have seen the reed-type meters built for typical 120 volt range and also for 240 volt range - not likely both in the same meter though without some additional parts.
2.) Current readings on each hot leg would be the norm. The CT would normally actually make the turns around your power lead rather than vice versa. The CT ratio needs to match your specific meter design so that your needle movement will scale accurately. The CT is already a coil and typical design assumes a single pass of the power lead through the coil.
Do not connect anything additional to your CT to Ammeter circuit (this will most likely screw up your readings). Take your frequency reading direct from one of your hot legs - separate wiring.
Thanks Gary;
I am using an Utterpower PMG
I use both 240V (deep well pump and refrigeration) and 120V for all else.
Your point #2....I thought single pass as well, but diagram with the CT(which was supplied with the ammeter) shows 1 turn around the CT. I am now measuring output with a Kill-A-Watt, so can compare single pass with one turn.
"Do not connect anything additional to your CT ammeter circuit".....that makes sense.
Really is simple, just want to be sure of no smoke!
Thanks for your quick reply and confirmation.
Hugh
