Update the serial number is 1360 S R2Z16 and it was made in Dursley. It runs fine and puts out 120 and 240 volts but I can't tell how many watts.I need a starter as this one is broken on the collar that bolts to the block. Would like to locate a rebuild kit for future use. TIA
Steve
I left the fuel tank petcock open and filled the crankcase with oil, is this normal or do I have a loose fuel line. July 10 added/ original oil filter system sucks can anyone point me to an alternitive oil filter system.
1360 should be the engine serial #
SR is the engine series
2 is the number of cylinders
Z is reverse rotation (comparted with UK standard)
16 is the year of manufacture, 1966
You have a fuel leak into the sump by the sound of things, check the banjo bolts on the fuel pumps etc. As all the injection stuff is inside, any leakage rapidly builds up the oil level :-))
I don't think an external oil filter was available for the SR, but the ST did have one and that may well be adaptable, you'd need to look at the relative points re fitting etc.
Peter
