Hello everybody,
Just like to show you my "baby's" and I hope you like them.
Finally they arrived safely
My new "baby", ready to go into my boat, born 1956
And my older lady, born 1938
Here they are sitting together happily
What a mess
Removing a stacked flywheel
This is where the fun begins :-)
Here we go, time for a clean up...
after her shower she looks much better
Cleaned parts came out quite well
After cleaning up, all the parts come out quite nice compared to myself, totally covered in oil :-).
Piston in perfect condition, only the piston rings are stacked, one ring and the oil scrapper ring has coming loose already from itself, will need some special attention …
Also got the stacked oil pump, valve guides, push rod guides and all other frozen parts moving.
Diesel filter snake too worn, cannot be reused, need new coil.
Injector and Fuel Pump will also need special care :-)
Removed also the crank shaft which was a real BIG job.
The outside ends from the crank shaft was quite corroded and it took me 2 hours to get this bugger out.
Bearing surface from crank shaft in excellent condition.
Conrod bearing is over the limit already, has to be renewed.
Will also renew the crank shaft main bearings as everything is open already.
One crank shaft bearing and the housing still stacked on the shaft, have to polish the shaft to get it out.
I am quite happy from the outcome, not many parts to replace.
I will need some parts, like an injector, fuel pump, piston rings, crankshaft main bearings, con-rod bearing, valves, valve springs ... not too bad
That's my boat in which one of my engines will go in
This is an 24' version which I will extend to 33', still working on it
Thanks for watching
