Author Topic: Lister Wire Sizes  (Read 4707 times)
ristle
Lister Wire Sizes
« on: June 14, 2014, 03:09:34 PM »
I came across a wiring diagram for the starter motor in a Lister Petter Handbook. They recommend a 37/0.9 from the battery to the starter and 80/0.4 between the starter and the dynamo. They must have forgotten that physical quantities consist of a value AND a unit. Do you have an idea which units they are referring to? Neither AWG nor SWG or mm^2 seem to make sense here.
Re: Lister Wire Sizes
« Reply #1 on: June 14, 2014, 11:20:04 PM »
80/0.4 is a metric equivalent. It is #7 gauge wire.
Not sure on the 37/0.9. I do see it crossing to a 25 mm2 or 9.7 mm od. That puts you somewhere around #3 gauge.
http://en.wikipedia.org/wiki/American_wire_gauge
« Last Edit: June 14, 2014, 11:27:33 PM by broncodriver99 »
M61hops
« Reply #2 on: June 14, 2014, 11:26:15 PM »
Hi ristle!  I'm just taking a guess here but how does 37 centimeters long and .9 centimeters diameter (9mm) of the copper?  That would look about like a starter cable to me.  ???  Just a guess!      Leland
« Reply #3 on: June 14, 2014, 11:30:27 PM »
Looks like it breaks down like this.
80/0.4 = 80 strands of 0.4mm wire
37/0.9 = 37 strands of 0.9mm wire
ristle
« Reply #4 on: June 15, 2014, 08:03:26 AM »
Indeed. 80*(0.4 mm)˛*pi/4=10 mm˛. 37*(0.9 mm)˛*pi/4=25 mm˛. Thanks!
« Last Edit: June 15, 2014, 03:03:58 PM by ristle »
