Author Topic: FR2 & head  (Read 2932 times)
FR2 & head
« on: April 24, 2014, 12:20:43 PM »
Not mine, Funds are low or I would be crowing about my newest purchase :(  The FRs are supposed to be pretty good engines. Make somebody a good unt for cheap
http://www.enginads.com/classifieds/showproduct.php/product/97759/cat/all
buickanddeere
Re: FR2 & head
« Reply #1 on: April 24, 2014, 03:32:50 PM »
I have no idea where buddy selling the engine and generator. Where he gets the idea that Canada is 50Hz.
Not the first time I've heard that line of BS either.
richardhula
Re: FR2 & head
« Reply #2 on: April 24, 2014, 05:04:53 PM »
Its a 50Hz genset and he makes a point that he used its 50Hz supply in Canada with the engine running @ 1500 rpm. He also points out it would run @ 1800 rpm (60 Hz with 4 pole alternator). Please tell me what I'm missing in understanding your suggestion he's throwing a line of BS???
millman56
Re: FR2 & head
« Reply #3 on: April 25, 2014, 03:43:17 AM »
I had the opposite problem of the set in Michigan with  an ex USAF, Morrison, 1800 RPM 60 HZ  FR2 set which is rated  10 kVA at that speed,  it`s an electric start with a very similar alternator/DC setup to the SOM alts,    with some tweaking of the excitation system it ran fine at 1500 RPM 230 Volts 50 HZ although with a lower output.    Not had much success with a Lima Mac 16 KVA 60 HZ alt run at 50 HZ these seem to have a HZ/Volt relationship that is cast in stone, another one is a Markon 4 KVA 110 Volt 60 HZ alt with 24 Volt starting windings and transformer regulated,  it has a  low  210 Volt output  series connected at 50 HZ, a possibility with this is to bypass the transformer and fit an AVR.
The irony is that these 60 HZ alts would be fairly desirable 3000 miles over the pond.
Depending on the regulation system of the Michigan alt I can`t see why it should not be possible to run this set at 1800 RPM for 60 HZ operation.
Mark.
