First, these comments are extracted from a post this week on
www.SurvivalBlog.com so go there to read the entire article. With the world quickly getting itself into a major problem, this info should be archived for emergencies/
The author stated that beyond the veggie oil option for us, he uses a triple filtered mixture of 85% recycled engine oil and 15% unleaded gasoline. Since our injection systems are similar to the single rail fuel system of the older Cummins that my son uses, I believe the fuel mixture ratio is valid as I have used that mixture in the 12 valve 5.9 Cummins.
Further, ATF may also be used in the brew but NEVER brake fluid. If the worst happens and there are abandoned vehicles on the road, they become doner sources for usable fluids of you drain the fuel tank bottoms. Stock up on filters to make your own fuel brew but I suggest a 2 micron final fuel filter to protect our 'Roids.
overbore
