Hey, two replies. Thanks,
The bore is 5/8. The two poly grove pulleys are 1" and 1.75". We've take the pulley to two machine shops to see if they could install a bushing and "No" was the response from both of them. We've talked about making it a single speed band saw as the shaft doesn't stick out enough to put two pulleys on back to back.
What terms should I be using other than "poly grove" in my searches?
Casey
