Author Topic: Startomatic flywheel weight  (Read 11052 times)
DirtbikePilot
« on: December 09, 2013, 02:51:17 AM »
I have a startomatic all apart and just for fun today I weighed the flywheels. This is a 2.5kva 6/1 startomatic. I've read several differing posts about the weight, but here's what my bathroom scale says:
The generator flywheel weighs 80 pounds.
The engine flywheel with the belt grooves weighs 260 pounds.
The engine flywheel without the grooves weighs 275 pounds.
Re: Startomatic flywheel weight
« Reply #1 on: December 09, 2013, 04:44:06 AM »
I see you don't mind abusing your bathroom scale!  :laugh:
Nice to see some real numbers for those flywheels!
millman56
« Reply #2 on: December 09, 2013, 07:59:38 AM »
I thought US bathroom scales weighed uo to a 1000 lbs load :laugh:
Mark, 200 lbs of taut muscle.
Bottleveg
« Reply #3 on: December 09, 2013, 09:52:00 AM »
I‘m stronger than I thought! But I must admit I do struggle with the 6/1 SOM flywheels.
Lister gives shipping figures of 1516lbs for the tank cooled 3kw 6/1 SOM and 1367lbs for the 4.5kw 8/1 SOM, although this is with the fabricated steel base and smaller remote box, which tend to be slightly lighter.
« Reply #4 on: December 09, 2013, 12:02:28 PM »
I recently shipped a 6/1 SOM with the cast iron base plate and accessories. It scaled around 1650 lbs. I did not know what the breakdown was for the individual heavy pieces though... the flywheels in particular.
BTW my bathroom scale only goes to 400# I believe, and it has a glass top so no way I could think of putting a flywheel on there!  :laugh:
« Reply #5 on: December 10, 2013, 06:48:58 AM »
...BTW my bathroom scale only goes to 400# I believe, and it has a glass top so no way I could think of putting a flywheel on there! ...
Like weighing a calf, you pick it up, stand on the scale, set it down and weigh yourself.  difference is the object  8)
« Reply #6 on: December 10, 2013, 02:57:28 PM »
275 lbs X 2 flywheels + the load of the firing stroke !
Wow, imagine all that weight carried by two Bronze sleeve bearings at each end of the crank and just a micron film of oil between the crank and the bearing.
Makes one appreciate how important it is to keep clean oil in the crankcase.  :o
With the roller bearing that the "modern" Listeroids have, one would expect the bearings to last forever if installed properly.
- Changfa ZS195 Generator
« Reply #7 on: December 10, 2013, 03:22:22 PM »
The generator flywheel is also likely significant for flicker reduction,  given it's higher rpm.
Pity our Rajkot manufacturers don't make the SOM flywheels.
« Reply #8 on: December 10, 2013, 03:25:45 PM »
One option is to buy the "near solid" 10/1 and 12/1 flywheels and mount them on a 6/1.
Apparently this makes a significant difference.
bschwartz
« Reply #9 on: December 10, 2013, 07:58:51 PM »
...."Like weighing a calf, you pick it up, stand on the scale, set it down and weigh yourself.  difference is the object"
Hmmmm...... 400lb weight limit of scale -235lb flywheel = your weight of no more than 125lbs !!!!!
If you weigh 125 lbs, and can lift a 275 lb flywheel onto a scale, I don't want to meet you pissed off in a dark alley....
-Brett
Schwen
« Reply #10 on: December 10, 2013, 11:22:43 PM »
165lbs maybe?
« Reply #11 on: December 10, 2013, 11:49:10 PM »
Well, I am 180# but not picking up any 200# + flywheels these days... too hard on the back, let alone the aging muscle tone!  :laugh:
« Reply #12 on: December 11, 2013, 06:28:39 PM »
I worked for a rather dicey contractor for a while.  Wow, did he teach me a lot.  One of the good things was to carry the tool to the job - not the job to the tool when possible.  And I think the Greeks popularized the inclined plane innovation.
Casey
Hugh Conway
« Reply #13 on: December 11, 2013, 06:58:57 PM »
Casey
Inclined plane in action: How I got it off the truck..............
Start-O sure is heavy. shipping weight for this one 800Kg.
Hugh
P.S. How to make these pictures larger??
« Last Edit: December 11, 2013, 07:04:30 PM by Hugh Conway »
1964 BMW R-27 project
