Author Topic: Power Line Listeroid 10/1 Genset For Sale near Atlanta GA $3000 [SOLD]  (Read 3984 times)
zacksstacks
As a hobbyist, I built this to power my workshop and for emergency backup power by following the advice found here - thanks gang! Works well to power my welder. No emergency use needed - yet. I has used less than a tank of fuel, so it is probably not or barely broken in.
It is located near Atlanta, GA, USA. I am posting on Craigslist locally and we'll see what happens.
http://atlanta.craigslist.org/wat/for/3914026958.html
[youtube]http://www.youtube.com/watch?v=gPX9Mm0GP_w [/youtube]
[youtube]http://www.youtube.com/watch?v=f5VcwrSlyko [/youtube]
Power Line 10hp, 1 cylinder diesel engine (Listeroid).
Mounted on steel frame with radiator and 7.5KVA ST alternator.
All bolted to 2200lb concrete block for stability.
Very heavy, not portable! Local sale would be best, obviously.
IMPROVEMENTS ADDED
modern oil filter
modern fuel filter
bronze timing gear
offset timing gear bolt
silenced compresser-type air filter
automobile-type muffler
thermostat
large radiator
Automobile electric starter.
SPARE PARTS
crankshaft bearing set
piston, cylinder, rings
head gasket
listeroid 2" hollow dipper
voltage regulator (unused)
glow-plug (unused)
« Last Edit: July 12, 2013, 10:37:53 PM by zacksstacks »
zacksstacks
Re: Power Line Listeroid 10/1 Genset For Sale near Atlanta GA $3000
« Reply #1 on: July 12, 2013, 06:22:00 PM »
Alright, sold and taken! Thanks Listerational, I hope you enjoy it as much as I!
« Last Edit: July 13, 2013, 12:16:20 AM by zacksstacks »
