Your loads (appliances, light fixtures) will drive the decision, along with the size of your house. For a very small cabin, you can use 10 ga wire to distribute 12VDC to the appliances you have. A small (Morningstar SureSine 300) inverter can power the electronics that need AC power.
But to scale things up to a cabin larger than 400sf, wire run lengths/gauge become prohibitive, you have more appliances that you can't get in DC versions.
Charging, will you have solar or hydro, or only the generator ? What's more reliable, and is capable of charging the batteries properly. Can it supply enough amps to de-stratify the batteries? What's the backup when something dies?
Does a DC alternator controller have enough setpoints for 2 or 3 stage charging ? Can it shut off the genset when batteries are full ?
I like the
http://www.microcogen.info/index.php?topic=50.0 page with a listeroid and an Axial Flux alternator paired with a MPPT Charge Controller.
