Author Topic: SCTF320 anyone?  (Read 13404 times)
SCTF320 anyone?
« on: June 19, 2013, 01:56:28 AM »
A client has the following Lister genhead dismantled and is in need of a manual or schematics to enable proper reassembly. This fits a British ST3 and is rated at 10kW 3-phase 50Hz.
ELECTRIC CONSTRUCTION
A.C. GENERATOR
FRAME: SCTF 320
Mc N°: A 10200 / 6
Voltage range: 380 / 220  PHASE: 3
Hz: 50                   R.P.M.: 1500                       CONN.DIAG. E 1184855
AC BRUSHES 32 x 10 x 25                            GM41.8
DC BRUSHES 22.2 x 9.5 x 28.6
CM6      4
Bearings                D.E. 340p                             N.D.E.    135p
F.RT       N°           064 – 33055 - 003
R.A LISTER
POWER PLANT LTD
STROUD ENGLAND
PLANT N° 1236L ST3.30VNA
VOLT: 380-220  PH: 3     WIRE: 4               HZ: 50
KVA: 12.5                           K.W: 100
AT:08 P.F
AMPS: 19.0                         AMPS: 15.2
A HAWKER SIDDELEY COMPANY
Any ideas? Thanks!
« Last Edit: June 19, 2013, 02:05:53 AM by dieselgman »
FrederickW
Re: SCTF320 anyone?
« Reply #1 on: June 19, 2013, 08:43:00 AM »
www.listerenginegallery.com   User Galleries   Frederick
Re: SCTF320 anyone?
« Reply #2 on: June 19, 2013, 09:23:33 AM »
Thanks for that Frederick!    I now see that the "Electric Construction" head is the same thing as Brush SCT.
Ernie
Re: SCTF320 anyone?
« Reply #3 on: March 04, 2024, 06:02:01 PM »
Hi Dieselman, i saw youre posting, from a long time ago, i have a lister/Bruch combination Frame: SCTF 225 and Conn.Diag E1184855, same as you wantend, dit you managed to get the information?
regards Ernie (Netherlands)
