I've always been curious about mounting a Lister with the cast iron base onto a very solid and rigid frame such as this one. I figure you have to be very careful that the frame is exactly straight and true otherwise you are stressing the cast iron base when you tighten it. I guess the solution if you aren't sure your base is true, is to put rubber of some kind between the engine and the base.
Thoughts?
Stan
