I use the 3 cylinder Eaton 2 stage pump on my 6/1, running at derated speed. Only a single B belt is needed, I could have saved some money on the 20" pulley. I've got enough power to pull 1000 watts on my ST-3 in addition. I was impressed with the support I got from Eaton, both before and after sale.
http://www.eatoncompressor.comI also use an air relief valve for control; the Eaton pump has pneumatic unloader valves on each cylinder which hold the inlet air valves open. I also use the unloader valves to "deselect" the compressor when I'm using the generator and have both belted. It still has a fair amount of drag so I unbelt it when I'm not using it for a while.
Here's a pneumatic control valve like the one I use:
http://www.compressor-source.com/Air_compressor_pilot_valve_125_150_psi_p/rcb-m-hu125-150.htmThe Harbor Freight unit wouldn't keep up with an air sander. It's rated for 15 cfm at 90 psi. You need about 4 times the rated CFM for the tool - so say at least 24 CFM at 90 psi for a sander. Air tools' stated CFM are rated at 25% duty cycle, so don't get fooled about their real air needs. That will take a larger 2 stage pump that a 6/1 can't handle. So then you must have a large tank to meet the demand, while the compressor slowly plays catch up. My air tank is 500 gallon.
I don't see a pulley size for the HF unit. I know B belts aren't designed to run on a flat pulley but I'd try it if the speed reduction worked out right. My Eaton compressor would be over the rated speed with it's stock pulley/fan with my engine at 650 rpm, so I had to buy a big pulley for the Lister. Very expensive.
Best Wishes,
Bruce
