I think I'm at a point of impasse.. I have the block all cleaned up on my 8/1 and assembled. I took out the studs for the block and cleaned up. I noticed an imperfection in one of the studs. It appears that when it was extruded, or however the Indians make studs, they didn't notice a split in the stud and just threaded the ends anyway. My question, is it safe to use??
One more question..
Do all Listeroids use valve caps on the end of the valve? Mine has none. They weren't on the valve assembly, nor in the bag of nuts and washers, and they weren't floating around in the crate like the pump lifter
Any help would be appreciated, Doc.
