I have never done the following:
There has been a bit of talk here about using induction motors as generators. They sync up with the grid and I cannot see why they would not sync up with a 6/1 running a ST head.
From what I understand, turning an induction motor over the syncronous speed, (more than 1800RPM in my example) will proved power. How much faster you turn it determines the power produced. From what I understand, 1830 RPM will be about right. Some here are using this method to run the power meter backwards on the home. Whlie I understand it is not the most efficient method of making power, it is likely such a setup would not be under full time use. So the slight loss in efficiency may be acceptable.
Once again, I have no idea how this really works.
Disclaimer, I'm not a sparky either.
From my understanding, once a induction motor is in sync, you can't actucally speed it up unless the driver is much more powerful than the motor, what happens is you *try* to drive it faster and this *pushing* is what generates the power.
If you have sufficient power to drive it faster it goes out of sync, vast currents flow and things melt and spurt flames....
1800 rpm / 60 = 30 revs per second, so 0.5 revs per hz, or full sine wave
1830 / 30 = 30.5 rps, so 0.5083 revs per hz, or full since wave
0.5 hz or sine wave is 180 degrees out of sync, max current flow, things go bang, 60 hz = 0.0167 sec, half that is 0.0083 sec so.....
0.0083 sec times 30 revs per sec = 0.249, or quarter of a armature revolution, which is right for a 2 pole head to be 180 out of sync
0.5083 - 0.5 = 0.0083 so your 1800 and 1830 rpm should put things 180 degrees out of sync every 0.249 / 0.0083 = every 30 seconds
I think that's right, wait for doug or someone to stop by and check my sums, and then tell me there was a 300 times simpler way of working it out... lol
