Ronmar, there is (1) valve in the system, on the outlet side of the thermosiphon. It's about 25 feet or so away from my Lister, above the machine, and it was closed.
Now, that being the case, I am also wondering if what you said was exactly right; that there was water in the line PAST the thermostat, and what was happening was that teh engine got wwarm enough, tstat opened, HOT water flowed out past the cold water sitting in the line, and eventually the water left in the line mixed with the water in the jacket, and somehow also mixed with the water coming from the inlet, which is always opened.
Hmmm....I bet you're right, because literally, there's not a thing wrong with how that engine runs.
I took the heat from the valve springs, I don't have a cover for them, so they're open, and I can shoot them. The top of the head meausred 275+-, so I thought that teh 300 or so was about right. Normally, the head is around 190-200, so that was hot, at least to me.
I do have a themostat connected to the upper hole with no bleed hole, it does gulp; I'd like to fix this. Tom, where do I drill a hole, please?
And Bruce, how'd you hook up a failsafe on your Lister? As Schultz said..."verrry inttterrrestink".
