I'm downsizing, looking for homes for the following:
1976 Lister SR2. Air cooled, CCW NA engine, 12v electric start. Currently, it's v-belt driven to a ST5 PS head. Engine has new fuel pumps and injectors, and starts on the first revolution, even in freezing temperatures. Decoked and re-sealed last year. Currently set up at 1400 rpm. (these fixed rpm weights and springs will go 1400 to 1750rpm ) On a heavy steel frame. This is a turn key generator that can power the whole house for about 3 hours to the gallon. Has murphy switch oil/fuel shutdown.
This SR2 is in perfect operating condition, and could be returned to variable rpm pump or marine service easily. Mechanic owned, no vices.
Spares:
1 fuel inj. pump
1 injector.
1 air filter element
variable speed governor kit, (800 to 2500 rpm) with original lister lever throttle (in case the buyer wishes to return the engine to variable speed service)
parts manual
service manual
"twin disc" clutch assembly cx105sp6 (new)
original pepperbox muffler.
bronze marine exhaust flex coupling, stainless steel triple pass muffler
external 5 gallon tank with sight glass, and water separator fuel filter
