Author Topic: ChangChai all aluminum EV 80  (Read 50392 times)
buickanddeere
Re: ChangChai all aluminum EV 80
« Reply #15 on: January 21, 2013, 07:52:27 PM »
Those look like a clone of the Yanmar V-twin . Built in both horizontal but mostly vertical shaft configuration for HP lawn equipment applications.
     There is a demand for the horizontal twins. Diesel Motor cycle enthusiasts swap the V twin diesel into bikes that used to have V twin gas engines.
Startomatic
« Reply #16 on: January 22, 2013, 12:24:50 AM »
I have a Yanmar L10. I will post some pix for a side by side size comparison. Not being familiar with big bike or American bike frame, it appear challenging squeeze. Particularly the added radiator.
I will leave that to the master craftmanship within us. Interesting you mentioned the Myanmar v twin, is this water cooled too. The Chinese has the L10 in v twin configuration but air cooled.
Lister 6/1 with ST5,Lister SL3, JP1
Yanmar Diesel L10,TS65,TS105 with Interpump hp head
Yanmar 3TN72, NT110 with ST5
Andoria S320
Kubota Z400 Twin Diesel with KEW 1500 hp head
Isuzu 25KVA Diesel silenced Genset
ChangChai EV80
JianDong 1115
Shineray250 watercooled- gasoline
ListerHRW3water
deeiche
« Reply #17 on: January 22, 2013, 01:03:47 AM »
the V-2 diesels put in bikes are air-cooled, popular chinese name was Winsun or Punsun.
4th British Diesel Motorcycle Rally 2008
this looks like the engine you have, scrolling through all the pictures it looks like at least one person in the United States has purchased one.
light weight water cooled v-twin diesel engine
Ohhhhh, interesting, the business located at the address shown on the shipping box in one of the pictures is none other than Thermoking Corporate Headquarters.
« Last Edit: January 22, 2013, 01:16:19 AM by deeiche »
bschwartz
« Reply #18 on: January 22, 2013, 02:14:50 PM »
The specifications show it as indirect injection (Swirl pre combustion chamber system)  Good for alternative fuels?
-Brett
maxx123
« Reply #19 on: May 23, 2013, 01:08:24 PM »
Hello I Just received 4 -EV 80 engines here in Eastern Ontario  I,ve put them on kijiji   really nicely built units. been translating a german repair  manual into English.   Of course I ordered extra parts basic stuff ,fuel filters,oil,air, injector nozzles .. also working on a modified wiring for the electronic actuator. fly by wire  throttle..
deeiche
« Reply #20 on: May 23, 2013, 11:35:31 PM »
Is this it, EV80 Diesel engine 20 hp Complete tier 4 epa?
« Last Edit: May 23, 2013, 11:38:22 PM by deeiche »
maxx123
« Reply #21 on: June 05, 2013, 10:03:24 PM »
Yes it is the same add.
Maxx
maxx123
« Reply #22 on: August 25, 2013, 10:03:35 PM »
startamatic, can you email me maxx123@hotmail
I know the stepper motor only travels about an inch   with the ecu    so getting a pulse controller to adjust it.  or the Y- manufacture of the ecu and controller I am unable to find anything about them ..
thx
« Last Edit: March 08, 2014, 04:11:20 PM by maxx123 »
Blue
« Reply #23 on: December 12, 2013, 06:24:24 PM »
Not sure I could live with the 3600 rpm tho'. Think I'll stick to my 1500 rpm ST1. We are 50 Hz here.
Owned; Lister ST1, ST2, JP4, LD1 & 2x Blackstone ERS8. Petter AA1, AC2 and still up for it !!!
maxx123
« Reply #24 on: March 08, 2014, 04:21:15 PM »
Been dealing with John at haige , had the  ecu controller and wiring harness for a generator  3600 rpm.. they resent proper  ecu and wiring harness for a variable speed control.
it can be controlled by a foot pedal, I modified the wiring to handle a hand controller.
there seems to be no service manual for this . I am using a Yanmar 2v78 manual. this motor is 100% copy.. except horizonal . the electronic wiring I have been figuring out the wiring codes, hope to have for requests , only left with the 3 pin diagnostic to figure out
will be posting engine running on youtube  today , ev80 diesel
really sweet sound
maxx123
« Reply #25 on: March 09, 2014, 01:49:32 PM »
 Here is the ev80  being tested
http://www.youtube.com/watch?v=VuhxeLGIX18
Blue
« Reply #26 on: March 09, 2014, 02:25:08 PM »
Why anyone would be interested in a 3600 rpm screamer is beyond me. Especially with a dubious pedigree. You would need about 2 acres to mount it somewhere that you could still speak and hear on the property. There are zillions of similar engines already EPA approved which you can get parts for. Again WHY?  ???
maxx123
« Reply #27 on: March 09, 2014, 02:53:58 PM »
Blue,
All diesels  running at 3600 rpm are loud,  if you saw the video .it was running between 400 rpm and 1300 . this is a exact knock off of the yanmar 2V78  like the Yanmar L100  is the same as the Chinese 186 engines
parts are available.
 This motor can be used for anything , motorcycle,boat, garden tractor shit even a generator you can have it run a smaller head at 1800 rpm even 1500 rpm..
Also this engine weight is 56 kg for 20 hp that is light
Blue
« Reply #28 on: March 10, 2014, 12:02:50 PM »
Whatever turns you on I guess. Let's see what remains in five years time.  :laugh:
maxx123
« Reply #29 on: March 10, 2014, 11:25:18 PM »
Had the ev80 running found that there are three bleeding bolts to remove air pockets in the cooling system
