I forgot,I am trying to quite down a 12/1 from jumping around.
I am exploring a new base with thin (.25" ) rubber feet
I need all the help I can Get
Don't we all !
What sort of substrate do you have - dirt, gravel, 4" slab, 10" slab ? Any mass on the frame besides the 12/1 ? Alternator ?
I have a 6/1 & ST5 on a frame, cross bolted to 2 large I beams. The 2 I beams are clamped at each end, with a U strap that traps the I beam, and the straps are bolted to anchor bolts drilled into a 8' x 12' slab, 12" thick, on packed gravel.
The 2 cross beams sit on a 1/4" thick, 4" wide, piece of oak flooring. The U strap also has a oak flooring isolator so metal does not bang on metal, and metal does not bang on wood.
I'd tried a stall mat, but the beast still walked around.
The battery shed 5' away, with an identical slab, bounces right along with the 6/1 slab. 10' away in the shop, you can feel the concussion on the floor there.
