Follow up on flywheel and crank problem, by now I have the engine completely
disassembled and took some better measurement as followed.
Crank Gibb slot 0.560 for both sides.
Flywheel on pump side 0.573
Other flywheel 0.575.
To correct this problem I am having 2 Gibb keys made to fit the slots.
Next BIG problem, the crank diameter where the flywheels fits is 2.123
The bore in flywheel is 2.130, besides being to big in diameter the service is
rougher than a corn cob, so that NEEDS to be machined. (See pix)
ON the other flywheel the bore is 2.128. This bore is nice and clean. Flywheels
are both 170.2 Lbs. so that is a blessing . I have not checked for balance yet, I think
it is better to wait for all the machining to be done.
In order to fix this my thought were, to have the crank welded with a wire feed welder
and than have it ground on a crank grinder.(we have a machine shop in town that has one)
Before I tore it down I did not know if I was able to do it, do to the fact I did not know the
diameter of the crank at the TRB whits is 2.250 so I can still remove or install a bearing when needed.
Any thoughts or comments? Thanks Tony.
