Well believe it or not I got the broken block all welded back together, it took me about two weeks and a lot of brazing rod but it's one piece of cast again.
I magna fluxed it, found all the cracks and drilled holes just beyond where they stopped then vee'd em out with a die grinder about 3/4" wide and brazed em up.
The trick is to heat the whole casting up and let it cool really slow after welding otherwise sooner of later you'll hear "Snap!" and there will be a new crack usually on the edge of the new weld.
Right after I weld I hit the weld a little with my needle scaler while it's hot, it's supposed to releive some of the stresses.
So, now I need a couple externally balanced flywheels, a crank, one main bearing holder a cylinder a head etc, etc, etc......................................................................
