Author Topic: Request advice  (Read 11397 times)
bandmiller2
Request advice
« on: July 21, 2012, 09:35:20 PM »
Guys I'd like your input on a couple of matters.As most know I have an air cooled ST-1 Lister direct coupled to a ST-10 gen head,that will be used as a standby unit,no real close neighbors.I am building a sound deadening shed with a poured concrete pedistal for the engine should the heavy welded base be bolted directly to the concrete or should I have some rubber between the base and the concrete.??Second whats the best practical exhaust system,I'am running it outside with flex pipe wrapped with fiberglass tape,common muffler or something in the ground.?? Thank You Frank C.
Fast cheap and easy are seductive sirens,its a rare man that does not court their pleasures.
Re: Request advice
« Reply #1 on: July 22, 2012, 01:21:23 AM »
Run that little ST on rubber vibration dampeners, or bolt to a timber.  Automotive style muffler will do fine. We have seen barrels buried in the ground for the purpose where sound is an issue.
macgyvermike
Re: Request advice
« Reply #2 on: July 22, 2012, 02:38:24 AM »
My 12/1 is on rubber dampeners when first installed 4 was not enough or they were in the wrong place and the frame was sitting on the concrete the vibration was felt in the floor and building. After adding more near engine all is smooth.
Mike
ronmar
Re: Request advice
« Reply #3 on: July 22, 2012, 03:25:11 AM »
Or bolt it to concrete and set the concrete on rubber...  My 6/1 is on a steel frame bolted to a 1300# concrete block which is resting on rubber stall matting about 3/4" thick.  Contains the thump pretty well and raises the generator up a little over a foot to make it easier to hand start and work on...
PS 6/1 - ST-5.
Re: Request advice
« Reply #4 on: July 22, 2012, 06:55:04 AM »
Nice wrinkles.
Casey
millman56
Re: Request advice
« Reply #5 on: July 22, 2012, 10:45:32 AM »
Heres a fire damaged one I rebuilt with an ST5 alternator, on load trial, fitted wth 6 isolating bobbins it jumped about, reverted to 4 and its fine.
Mark.       PICT0810[/img]
millman56
Re: Request advice
« Reply #6 on: July 22, 2012, 11:18:00 AM »
[imghttp://listerenginegallery.com/main.php?]http://[/img]
[imghttp://listerenginegallery.com/main.php?][/img]
millman56
Re: Request advice
« Reply #7 on: July 22, 2012, 11:24:44 AM »
Derr!!!! failed again,  anyway the images are in my gallery.
Mark.
bandmiller2
Re: Request advice
« Reply #8 on: July 22, 2012, 12:22:02 PM »
So the purpose of the rubber mounts is to keep the vibration "thump" from transfering to the floor.Always thought it was to lessen the strain on the engine and its base.I have some of the pads they put under heavy machinery about 3/4" should that do the trick under the welded engine/gen mount.?? Thanks Frank C.
millman56
Re: Request advice
« Reply #9 on: July 22, 2012, 01:59:11 PM »
Frank,  you have to have the right amount of resilience in the mounts if too stiff the base jumps about, too sloppy and the set jumps about, there is a science to it but I just make an educated guess, the sets tend to wobble a bit when running up to speed and when slowing down also things change a bit from unloaded to loaded conditions. The set in the photos doesn`t move around at all.
Mark.
OKFarmer
Re: Request advice
« Reply #10 on: July 22, 2012, 04:58:43 PM »
Frank, my KOEL 8/1 project thread under engines has hit this debate as well. My set while building was sliding on the shop floor when I would test run. When I put a rubber mat under it it wanted to hop, hop, hop.
If you have too much rubber the thing will be pulling up on your anchors following each power stroke. Not something you want.
My wood blocks seem to be taming her nicely (see my vid in that thread).
bandmiller2
Re: Request advice
« Reply #11 on: July 23, 2012, 01:33:55 PM »
I'am thinking of four to six hockey pucks, center drilled, and half set in cement to support the welded frame on the concrete pedistal.If I don't have to put the rubber directly under the engine and gen. that would be good as the couplings are already aligned.Has anyone used hockey pucks.?? thanks Frank C.
camillitech
    • life at the end of the road
Re: Request advice
« Reply #12 on: July 23, 2012, 09:03:21 PM »
Bolt it directly into one ton of concrete just as RA Lister recommended,
Do NOT rubber mount it and certainly do NOT mount it on a railway sleeper.
RA Lister stipulated solid concrete bases for all there generating plant that was to be run for an extended period for a very good reason. Flexible mounts means broken exhausts, failed electrics and work hardened copper wiring that will snap.
Rubber/flex/wooden mounts are only for in boats where there is no other option, mains failure sets that run infrequently or shipping containers and other moveable structures.
Don't believe me, just check out the manuals, OK, I know there will now be a deluge of folk telling me how 'damn fine splendid' there flexible mounts are but I know a guy in his sixties that served his time with RA Lister in Scotland before branching out on his own. All he does is go around remote highland estates and islands fixing and installing Lister generator sets and he's been doing it for forty years.
He once told me that his 'bread and butter' was fixing wiring problems caused by flexible mounts and railway sleepers.
Think about it chaps, why would they specify tons of concrete if a few rubber mounts would do the job.
This is my old ST2 running with a pound coin on the rocker cover, loosen any one of the mounting bolts just one quarter of a turn and it will fall over.
I see yours is for a standby set Frank so you may well get away with rubber, but long term you're just asking for trouble. Remember these engines were designed to run 24/7 and that's what they'll do if mounted correctly.
Cheers, Paul
http://lifeattheendoftheroad.wordpress.com/
HR2 Lister 12Kw
ST2 Lister 7Kw
SR2 Lister 6Kw
SR1 Lister 3Kw
Tom
  • Green power is good.
Re: Request advice
« Reply #13 on: July 23, 2012, 10:52:20 PM »
"Think about it chaps, why would they specify tons of concrete if a few rubber mounts would do the job."
Maybe R.A. Lister had secret investments in all the concrete plants in England.  :P ::) ;D
Tom
camillitech
Re: Request advice
« Reply #14 on: July 23, 2012, 11:42:03 PM »
 ;D  ;D  ;D and Scotland  ;)
HR2 Lister 12Kw
ST2 Lister 7Kw
SR2 Lister 6Kw
SR1 Lister 3Kw
