Author Topic: Valve timing for the 12/1 degres from TDC converted to inch around circumference  (Read 2984 times)
sframe
Look for spec's on valve timing and a diagram for the 12/1, and the degres from TDC converted to inch's around circumference
for 20 inch fly wheels. if some one all ready has this inforation readly avaible it would be great!!!!!!!!!!!
10 degree's = 1.75" on the circumference
(1 degree = .175")
once you know the actual degree spec, you can do the math from there.
for instance, 18degree btdc would be
18 * .175 = 3.15" or ~three and an eight inches is close enough.
