Author Topic: Too many generators ???  (Read 8732 times)
bandmiller2
« on: June 27, 2012, 01:19:28 AM »
Fess up guys how many generators do you have. I've got an old Dayton 14 amp,two military 2 cyl about 13 amp,four cyl. military 110/220 single and three phase on a trailer and my favorite ST-1 lister and st-10 gen.The small ones are 3600 screamers the four cyl mil.goes through gas like grass through a goose.The lister is for long term outages. Frank C.
Fast cheap and easy are seductive sirens,its a rare man that does not court their pleasures.
ronmar
Re: Too many generators ???
« Reply #1 on: June 27, 2012, 02:55:57 AM »
One listeroid 6/1-5KW ST head and one Changchi with a 10KW brushless ST head.  Wouldn't mind having another 6/1-ST5 to run the set in parallel:)
PS 6/1 - ST-5.
« Reply #2 on: June 27, 2012, 03:27:41 AM »
complete or incomplete?
ready to run or in progress?
last count, 5 or 6 that make power, enough parts to make maybe that many more
and that doesn't count DC generators, last count i have maybe 50 alternators, ranging in size from 160amps to 320amps.
basic answer, too damn many!
« Reply #3 on: June 27, 2012, 12:15:48 PM »
Metro 6/1 w 5KW ST
Changfa 1115 w/15KW ST
Changchai? 195 5KW
B&S screamer 3500 W
And a 192? Petter oil engine factory genset on its way from B.C. Canada as I type ;)
« Last Edit: June 28, 2012, 01:42:56 PM by 38ac »
« Reply #4 on: June 27, 2012, 05:30:22 PM »
Same as Ronmar, but my Changchi has a Markon head and the fan is missing the blades so it can only be used short term until the head heats up. Then I also have a Miller Roughneck welder/generator that needs the Kohler engine rebuilt. I'm off-grid too and really should have more generators.
xyzer
« Reply #5 on: June 28, 2012, 12:39:05 AM »
1-6/1 Vidahta st5 160 amp 110-555 leece nevell 12v starter (portable)
1-6/1 Power Solutions ST5 (portable)
1-Kubota Z482 5000w
1-Kubota EA500NB 4000w Winco 160 amp 110-555 leece nevell
1-Lincoln 11,000w welder
2-generac 5000w screamers
...........I am feeling sick right now...... :P
Vidhata 6/1 portable
Power Solutions portable 6/1
Z482 KUBOTA
rleonard
  • Mattoon, Illinois
« Reply #6 on: June 28, 2012, 04:41:53 AM »
6/1 Lister driving a Kato
16-2 Lister + ST15
Onan DJB 2 cyl diesel.  6 KW
Somwhere, a Generac 8 HP briggs
Under construction; Ruston Hornsby 17 HP pulling a 20kw Leroy Sommers Gen head.
Too many
Veggiefuel
  • Energy Machines Ltd.
« Reply #7 on: June 28, 2012, 05:34:28 AM »
- 6/1 Listeroid with a 5kw ST head
- 6/1 GM90 Listeroid with a 4 kw head
- Changfa R190 with a 4kw head
- Launtop Air cooled diesel with 180amp Leese Alternator
AND.....
Costco LED flashlight with "hand crank" charger  ;D
Horsepoor
  • West Palm Beach, Florida
« Reply #8 on: July 08, 2012, 05:38:45 AM »
GTC 20/2 850 rpm - 15 kw ST
Metro 6/1 800 rpm - 7.5 kw ST
Generac 10 kw gasoline
Chineese 4 stroke portable 3500 watt
Two 800 / 1000 watt 2 stroke portables
13 HP CAT with 10 kw ST in build phase
bschwartz
« Reply #9 on: July 08, 2012, 06:18:12 PM »
Metro 6/1 - ST-5 head
1200 watt cheap chinese two stroke
unknown chinese r170 (4.5 horse I think) with a Voltmaster AB50 in progress
-Brett
shipo
« Reply #10 on: July 20, 2012, 02:14:43 AM »
Changfa 195 / ST-10  -Primary-
Onan DJE-3CR 6kw -Secondary-
Yanmar TS105 5.3kw Winco -In restoration process-
Changfa 170 /  ST-3 –Waiting to be assembled –
JKson 6/1 ST-5  -someday???-
Jkson 6/1  kit –spare-
McCulloch 5.7kw screamer  w/120hrs (Wilma Hurricane)
…wife confirmed that I have room for two more ;) ;)….
Changfa 195/10k
Changfa 170R
