Author Topic: Injector pump manual  (Read 8076 times)
Tom
  • Green power is good.
« on: June 14, 2012, 05:40:06 PM »
Does anyone know where I can download a manual for a 6/1 injector pump. My origional pump started leaking out the bottom, so I'm now running my spare. I've got the rebuild parts, but don't want to have it spring apart and then try to figure how to get the parts back together.
Tom
getterdone
Re: Injector pump manual
« Reply #1 on: June 14, 2012, 06:27:07 PM »
yea, i really need one too!
                                    getterdone
listeroil
« Reply #2 on: June 15, 2012, 03:47:44 PM »
Here you go
Mick
Tom
« Reply #3 on: June 15, 2012, 06:02:18 PM »
Thanks!!! It looks like "special #24 Fig 11" is needed. Can an alternative tool be used that may be found in a DIY workshop???
Tom
getterdone
« Reply #4 on: June 15, 2012, 11:13:37 PM »
i know whats wrong with my old injection pump. just looking at the diagram.,i see that that i've been putting the delivery valve in upsidedown.
thanks for posting this manual.    getterdone
Tom
« Reply #5 on: June 15, 2012, 11:37:44 PM »
Gitterdone, how did you get around the need for special tool #24?
Also noticing item 3 in the trouble shooting section about heavy carbon deposits. I guess this is why the original Listers had the pawl on the rack to limit full throttle.
Tom
getterdone
« Reply #6 on: June 16, 2012, 04:00:22 AM »
you should not need that tool unless your pump is leaking so bad that your getting fuel into the crankcase.
in that case i would buy a new pump. i guess you could replace the pump plunger and sleeve.
sorry it took so long to get back  my computer locked up.
i use laquer thinner to clean the gue that veggie oil makes when in contacting with air.
bigblockengine9074
« Reply #8 on: July 16, 2012, 04:04:49 PM »
Here you go
Mick
Thank you for those perfect pictures of the manual they help articulate the process so much better now!
you should not need that tool unless your las vegas construction pump is leaking so bad that your getting fuel into the crankcase.
« Last Edit: July 21, 2014, 01:07:56 AM by bigblockengine9074 »
