Author Topic: power for electric radiator fan?  (Read 22464 times)
Re: power for electric radiator fan?
« Reply #15 on: June 11, 2012, 11:45:28 PM »
True Bruce, they do draw 4-5 amps of power, but they will only run long enough to cool the engine then shut off. They are nicely ducted to ensure the air flows through the radiator too. And at 14" diameter they are the right size for smaller radiators. They are commonly available and low cost too.
« Last Edit: June 11, 2012, 11:48:05 PM by Tom »
Sfene
« Reply #16 on: June 13, 2012, 01:09:30 PM »
Try surplus city, all kinds of ac and dc fans. I use 225 cfm ac fan with a medium size radiator, 3500 watts normal load, 190f temp sender to relay which picks up fan. 2nd sender 210f to 2nd relay picks up taco circ pump.
ronmar
« Reply #17 on: June 13, 2012, 03:08:59 PM »
How about multiple 4" computer fans.  Available about anywhere, very robust, multiple fans leaves out single failures, Add in two small power supplies and a set of snap switches for a redundant system...
PS 6/1 - ST-5.
« Reply #18 on: June 13, 2012, 04:07:33 PM »
I really like Ronmar's  computer type box fan(s)  idea, but I think I'd go with the AC version for simplicity.  Very low power, redundancy by design, and a good match for our very limited airflow needs. You could consider eliminating the thermostat switch, also.  If you had 3 set close to the radiator, I don't think you'd even have to make a simple shroud, and any one failing would still leave you with plenty of airflow.  They are available for 120 or 240VAC.  mpja.com has had them cheap, surplus, in the past.
I woudn't want the 1500+ watt start surge of a 500 watt attic fan that happens just as my water well submersible pump tries to start, but then I've only got a 3KW ST generator head.  The DC auto fan would be better as far as start surge issues, though again it is way more fan than we need.
« Last Edit: June 13, 2012, 04:13:19 PM by BruceM »
« Reply #19 on: June 13, 2012, 05:41:08 PM »
Yes Murphy will make sure that anything that has a start surge will start all at once, usually at the most inconvenient time. Computer fans and a computer power supply would be an inexpensive way to go. One could even use it to charge a small 12v battery too.
« Reply #20 on: June 13, 2012, 07:37:33 PM »
Hi ronmar,
Did you know you can use most any PC power supply to run these really quiet fans?  I too am fascinated by these couple of watt workhorses.  Don't forget a used laptop / printer brick that has the right voltage (or close and you can series them for different voltage needs).
Casey
ronmar
« Reply #21 on: June 13, 2012, 08:47:46 PM »
Hi ronmar,
Casey
Yes, you can:)  12V wallwart P/S's are also inexpensive and readilly available, and perhaps a bit simpler...
PS 6/1 - ST-5.
bandmiller2
« Reply #22 on: June 13, 2012, 09:04:53 PM »
Carpenter,I'am in a little late on this fray but I believe multiple ac computer fans is the way to go.They could be staged on to regulate engine temp.and lets face it when the engine needs cooling you have ac power. Frank C.
Fast cheap and easy are seductive sirens,its a rare man that does not court their pleasures.
cujet
  • Lister power rules!
    • www.cujet.com
« Reply #23 on: July 31, 2012, 03:43:10 PM »
I use a 12V power supply from  www.mpja.com
"Marlin P. Jones" electronics in West Palm Beach has an incredible supply of power supplies. Many of them are quite inexpensive.
« Reply #24 on: July 31, 2012, 06:18:45 PM »
There are lots of 12V supplies on ebay sold for LCD monitor replacement power supplies.  Typically $10 including shipping.  I still prefer the AC muffin fans- less hardware to fail.
deeiche
« Reply #25 on: July 31, 2012, 08:57:36 PM »
Not the cheapest solution but perhaps you could use the waste exhaust heat to run a thermoelectric generator.  There are links in the wiki page to various manufacturers.
ronmar
« Reply #26 on: August 01, 2012, 12:49:34 AM »
If I was going to do anything with exhaust, I would go Bruce M's route and use it to induce a draft to pull air thru the radiator.  WAAAY old school, but well proven, dead simple with no moving parts, and almost zero chance to fail...
PS 6/1 - ST-5.
« Reply #27 on: August 01, 2012, 01:08:09 AM »
It's true, with induced draft loss of cooling  means the engine must have stopped. :)
Stan
« Reply #28 on: August 14, 2012, 05:05:35 AM »
Using the thermoelectric generator on the exhaust is the only system that will not rob horsepower from the engine.  Penelope has the fixed radiator and it robs 1/3 hp from the engine to run the fan, using power from the alternator to run a 110 or 220v fan also robs power from the engine.  Using an electric fan with heat sensor on/off perhaps will be a bit more efficient but there's no defeating physics when you need to power a fan from an engine.  Even systems to put vanes on the flywheels to blow air through a fan rob power.
Stan in Kimberley
ronmar
« Reply #29 on: August 14, 2012, 02:59:57 PM »
Stan in Kimberley
Stan
  Induced draft won't rob any HP from the engine either:)
PS 6/1 - ST-5.
