Just a couple of questions for general comment.
1) Would it be fair to use the following designations for engines?
Listeroid = Vertical cylinder, TWO flywheels, watercooled.
Petteroid = Vertical cylinder, ONE flywheel, water or air cooled.
Changfa type = Horizontal cylinder, one flywheel, water cooled.
Even though we know that all of the combos were used at some time.
2) Thinking about converting a Listeroid to LP gas as fuel.
Install LP gas carburetor, pull injector and install spark plug, remove unneccessary items (injector pump, etc.). Could also keep injector and use as ignition source for LP. Intent is to use Listeroid as fixed generator system running from large LP gas tank for backup power. Would eliminate storage of Diesel/BioDiesel/V.O. and carbon buildup, etc. Make any modifications to create a dependable, slow speed, efficient engine. Also, might meet EPA requirements.
Any coments or suggestions welcomed.
