Author Topic: VA "One" Teardown  (Read 24824 times)
Re: VA "One" Teardown
« Reply #30 on: September 05, 2012, 01:43:02 AM »
We also have quite a few of the old Lister books for various SOM and similar types. They have quite good electrical schematics. File sizes are excessive so would have to arrange for access via a cloud service.
ottawavalleyboy
  • HP is for show....Torque is for go.
« Reply #31 on: July 07, 2015, 03:38:15 PM »
At last I have found the time to continue my work on my VA! While waiting for some tune up parts to arrive I had a look at the cooling shroud....it appears that the fan/flywheel has to come off first if I want to paint it easily,otherwise it will get painted as it sits....
2005 smart fortwo diesel, 95 Toyota tacoma 4x4 gasser, 2011 argo 8x8,and most recently an aircooled Lister 7.5 VA
potter
« Reply #32 on: July 14, 2015, 01:22:06 PM »
About time  :)
ottawavalleyboy
« Reply #33 on: October 12, 2015, 07:09:30 PM »
« Last Edit: October 12, 2015, 09:05:17 PM by ottawavalleyboy »
TxBlacksmith
« Reply #34 on: October 12, 2015, 09:00:17 PM »
Could you give me some info on the belt in your setup?  It looks exactly like what I need for my SOM... ;D
ottawavalleyboy
« Reply #35 on: October 12, 2015, 09:40:07 PM »
My belt's part number is  2RB103  Mfgr is "Jason" the PN is for a two rib "B" profile and 103 inches circumference, I don't know what profile the SOM grooves are so you would have to verify that, I'm not sure if a bonded 2 rib belt is even needed in your case you may do just as well with 2 individual v belts but that is something you will have to determine for yourself, I picked my belt up locally for $45 or so
