Well after waaaaaaaaaaaaaay too much work, sweat and swearing I am where I am.
I fabbed up Quinns tool idea and after about 3 turns on the lead screws the head of the key POPPED right off.
OK, lets try this again....I fabbed the drill guide, also Quinns idea, and drilled the 1/8" with no problem. After drilling the 5/16" I could see that I had just a little metal left over so I made a longer and larger drill bit...11/32" and went ahead....I kept seeing metal at the bottom of the hole so I kept drilling....stupid me....The flywheel was almost against the case so I could not see or get anything between them (both sides were like this)... after drilling, trapping and cussing some more I welded a threaded rod to what was left of the key and put my slide hammer on that....Half the key came out after about 12 or 15 good hard wacks.....The other half came out after much tapping and prying and pulling.......so here we are.....
The damage on the crank I do not consider to be a super big deal, but maybe it is
Worst case would be to send it out and have it welded and ground or I'm thinking a dab of JB weld and little file and paper work. The damage is just into the seal area.....perhaps a sleeve and different seal......Maybe turn the seal the other direction and to the good area.....My options are not limited I don't think.
What do you guys think
Thanks for all the help from everyone !!!
32 coupe
