Thanks, Quinn. I should have remembered to credit Hotater (Jack B) on the bearing issue, as well as John F. I think Bob G was an important technical contributor to the grooveless upper shell, hollow tube dipper fix as well. I'm running my 6/1 on XYZer's hollow dipper, 55 mil offset idler bolt, and JohnF's bearing shells.
My only wear gripe is that even after finding the black sand and grease under the crown of the piston, I still have a minor unlocated sand source, my bearings show some sanding (not major) and I have been replacing them every 3rd oil change (600 hrs). This despite the big door gravity fed oil filter box, which I re-stuff with cotton rags every oil change. (Inspired by Hotater's original big door filter.) Note that my 6/1 is an older Metro, which has no lower oil bath, so there's no place for grit to settle away from the splash dipper. The oil capacity is 3.5 quarts.
So I wish I'd done as Quinn did, and stripped the the case in a lye bath, then glyptol'd it. I had flushed and poked and inspected my case carefully, but I guess there was hidden treasure under the green paint somewhere that I missed.
