I concur that the Indian copies sometimes leave much to be desired... however, the basic design has proven to be successful over a half a century in a lot of different engine models and aside from the normal wear-and-tear issues, gives very little trouble. I say check out your components - if the machining and fit is proper and the unit pumps as it should - you are golden!
