Yes, hello and thank you for the welcome.
I am picking up what ur putting down regarding weight evaluation prior to drilling/adding weight.
I'm a little confused regarding where you take off or add weight to, i took your picture and added red dots to where it appears you made your holes and im wondering if you could possibly expound as to why that is the area you chose to drill.
Also i am seeing some variation on determining offset weight, mainly in that some calculations include adding the big end of the con rod after determining percentage of small end of con rod and piston. Could you set that in stone, so to speak.
Thanks for the time.
Hello and welcome! No stupid questions here.
A. In one of my posts in this thread I said that a person needs to evaluate both wheels before he starts drilling and adding weight an attempt figure out a course of action so you dont end up drilling holes to accomplish one goal and adding weight over them to make another goal. As an example if you calculate the off set weight in two flywheels and flywheel A has 10oz more offset weight but also needs the weight centered you would want to try to drill holes in an are a that not only centers the weight but also serve to lessen the off-set. So many variables that a person just needs to evaluate his own wheels and go from there.
B. In every Indian Engine I have worked on they needed more off set weight, not less so in that case I would add weight to the off set of the lighter one to match the flywheels.
Once you get the flywheels to a corrected state the rest is dead easy. Start the engine and if it jumps or walks in a circle you have something wrong, fix before going further. Assuming it is either jumping straight up and down or walking a straight line. THEN using the Mr X method add weight to the side opposite the chaulk mark ONLY centered at the heavy spot or 180 opposite. and in equal amounts for both wheels.
