The KOEL 8/1s we have here are fitted with 23 3/4" solid wheels with cutouts, some of the replacement 8/1 wheels we have received wound up being 23 1/4" diameter.
David Edgington lists 31 variations in the Original Dursley flywheels and refers to the section as "Unraveling The Flywheel Conundrum"..."undoubtedly the most complex area clouded in mystery" - he provides the best single source for this detail and apparently teamed with David Harris also from Lister/Petter to do all that extensive research.
I believe that the main lesson is not to assume anything about a standard flywheel and treat each engine as unique, which after all - indeed they are.
