Author Topic: 28v 570 amp alternator !!!!!!!  (Read 6756 times)
bschwartz
-Brett
Re: 28v 570 amp alternator !!!!!!!
« Reply #1 on: December 18, 2011, 05:42:22 PM »
Yup.
I sure wish it was 570 Volts by 28 Amps.
Casey
« Reply #2 on: December 18, 2011, 06:31:15 PM »
Military spec... hard to tell if those are truly "new" as stated in the add or are take-offs as they appear to be in the photo. The presentation leaves me a bit wary, especially since it is a vulnerable piece of electrical and a bit pricey to boot.
carlb23
« Reply #3 on: December 18, 2011, 06:34:36 PM »
Yup.
Casey
Casey,
Why don't you get a used 3phase 480 volt AC motor and rectify the output.  you will need to spin it around 1875 to 1900 rpm i think.  I don't know what hp you would need , but i suspect that anything above 7hp would be enough.
« Reply #4 on: December 19, 2011, 03:58:23 AM »
Hi Carlb,
Because no one has actually done it that's talking.  Every time I follow a lead it turns into the future tense.  I've got the  7 hp.  And I've got the 25 inch flywheels.  I'm looking for a three phase generator.  I think my tractor PTO idea is solid but I'm rigged for twin V belts or serpentine will work as well.
I'm going to an industrial garage sale tomorrow to look at three phase motors.  What should I be looking for besides 3 phase 480 volt?
Casey
« Reply #5 on: December 19, 2011, 04:28:28 AM »
You will want something around 1800 rpm on the name plate.
listerdiesel
« Reply #6 on: December 19, 2011, 10:02:23 AM »
Looks like they are used on the Caiman RG33 vehicle, used by the US Army:
http://www.army-technology.com/projects/rg33-mrap/
Alternator referenced here:
https://safety.army.mil/LinkClick.aspx?fileticket=gkUxtA%2BSysI%3D&tabid=818
NSN Number:  2920-01-560-3613
Peter
carlb23
« Reply #7 on: December 19, 2011, 12:39:43 PM »
Hi Carlb,
Casey
it should be a 1725rpm 3phase, but i don't see why you cant use a 240 motor somewhere in the 7hp range should work.  Do not get a 3400rpm motor. how much voltage DC do you need?
I read somewhere where they are using AC motors as grid tied synchronous generators in some hydro setups.
deeiche
« Reply #8 on: December 19, 2011, 02:10:54 PM »
Hi Carlb,
SNIP
Casey
I've seen milspec 3 phase equipment forsale in Gov't auction.  I know you are located in Hi, but I don't know where the auctions are in relationship to you.
« Reply #9 on: December 19, 2011, 05:28:19 PM »
This tread is really about these bad boy alternators so I started another one about grid tying your generator.
http://listerengine.com/smf/index.php?topic=6159.0
Casey
