Carl, I took a picture & now am trying to figure out how to upload it. I click on the "Insert Image" tab, and get the
. I don't get this, (sorry for my computer illiteracy). I thought there would be a "dropdown box" where I'd go to the file & so on. Any ideas?
The way I'm understanding this, when you tighten the spring, it raises the RPM's, and loosening the spring lowers the RPM's. I have the spring as loose as I cen get it, and the RPM's were still too high, so I went to adjusting the connecting linkage, making it longer, in effect holding the IP closed farther. (less throttle). As I adjusted the linkage to get the RPM's down, (they did decrease) it seemed like it was working, then when I went to start it, it didn't get enough fuel, so I adjusted it back towards more fuel (bent the connecting linkage a little) it started, slowly, and then went way up in RPM's again, as it should.
On the rack being open, not sure I get this. (Reading as fast as I can about the "rack"). Is the premise that when you open the fuel cutoff lever, that the injector pump is supposed to open all of the way, until the engine starts running, THEN it gets pulled back (to a lower RPM)?
