Wabbit Anyone? MMMMM
The "Semi Closed Loop" If I get it, sounds like a "sledgehamer" EGR system.
How can it not be a "zero sum" situation.
Cold oxygenated air in>Compression>Injection and Combustion> Hot exhaust (with some unburned fuel, particulates, and all the other normal exhaust "stuff") out>
Hot spent "exhaust" (see above) in> ??out??...(???Diesel Equivalent of an Asthma Attack???) Leaky gaskets "might" help?
As Scott (shipchief) put it so eloquently:
Suck>Squeeze>Bang>Blow (I assume oxygen is involved in the "suck" part...)
Is there something I am missing here???
Kevin
