Thanks Deiselgman. Here i go again thinking without the brain. I thought it might be possible to bore out to make it up to 6/1 spec. As I have this cylinder, and it was originally on this engine. and was trying to do things in a cheaper way. getting towards £275.00 for cylinder piston n rings. for the 6/1 then idler gears, all adding up into GBP. 's --- sorry I'll have to start writing things down and check the measurements. Another question does the compression, chamber cup come out of the cylinder head, as you know mine is leaking a bit, when screwed fully in. I was looking at this 3/1 spare/head I have and it looks like it will come out.? There are two, one that comes out with the screw,and one that is way down inside,at the bottom of the threads. Thanks Newlister.
