Author Topic: Leather oil seal  (Read 4569 times)
triumphman
Leather oil seal
« on: September 24, 2011, 10:31:33 PM »
I have a new leather oil seal for the front of my JK6 it seems really hard, do they need soaking in oil before fitting.
Re: Leather oil seal
« Reply #1 on: September 24, 2011, 10:38:04 PM »
The leather seals always require a good soak in lube oil before forming to the crankshaft. Old stocks can be dried and hardened up from age.
triumphman
« Reply #2 on: September 25, 2011, 10:14:47 AM »
Thank you i suspected that was the case
listard-jp2
« Reply #3 on: September 25, 2011, 02:07:39 PM »
I know this sounds a little unorthodox, but IMHO for better and / or faster results, soak the oil seal in hot oil for improved penetration of oil into the leather parts of the seal. I myself heat the oil in a tin can over a camping stove with the oil seal, until it starts to boil, then after leaving it to cool its ready to use.
This approach allows you to use a thicker oil if you wish, that is likely to stop in the leather for longer when its on the engine.
