I am checking out a TS2 driven 9kw gen set that the seller says "This diesel has mechanical injectors and will run on almost any available heavy fuel including filtered french fry oil."
When asking about WVO filtering etc on another part of this forum, dieselgman says "Speaking strictly to your question about Lister TS2 and WVO - Since this is a direct injected engine and has fairly small ports and passages, carbon build-up will be an issue. I believe you will have to preheat your fuel or convert it to biodiesel if you expect to burn it in a TS series engine. If you preheat, I believe it will run through the TS fuel injection without an issue. That process does get a bit complicated."
I am very new to this whole process and am trying to SIMPLIFY this as much as possible.
I am wondering if anyone can help me with the following:
1 - Are mechanical and direct injectors the same thing?
2 - Could this TS2 have mechanical injectors?
3 - Is there an easy way to determine the type of injector?
Thanks for any guidance
Dieselgman knows what he is talking about, While i am not familiar with the TS2 I will try to help with your questions as best I can.
No, not all direct injectors are mechanical and not all injectors are direct injection
Yes it most probably does
Yes a mechanical injector will have just he fuel pipe going to it, an electrical injector will also have a wire going to it.
