Author Topic: Yanmar TS130 parts source required  (Read 12363 times)
yow ling
« on: July 19, 2011, 08:02:23 AM »
Hi,  I'm new to this forum, I shouldn't really make my first post a begging one, but will anyway !
I recently bought a 6.5kva Yanmar diesel generator set, It had seized the piston, and was supplied in parts
Its actually in reasonably good condition, Ive ordered a new piston and head gasket, but missing from the big kitset is the exhaust rocker and the rocker support the guys I'm getting the piston from have no listing for these parts, does anyone have any ideas where I can get these from?
The engine model is yanmar TS130, I'm guessing the rocker stuff is probably common with other TS and TF
Mike
Startomatic
Re: Yanmar TS130 parts source required
« Reply #1 on: July 19, 2011, 11:08:35 AM »
if you can give me the engine serial number i can probably get you the parts. be it new original Yanmar, clone made in Thailand or used part salvaged from donor engine.
you  call sign sounded oriental. are you from the east?
Lister 6/1 with ST5,Lister SL3, JP1
Yanmar Diesel L10,TS65,TS105 with Interpump hp head
Yanmar 3TN72, NT110 with ST5
Andoria S320
Kubota Z400 Twin Diesel with KEW 1500 hp head
Isuzu 25KVA Diesel silenced Genset
ChangChai EV80
JianDong 1115
Shineray250 watercooled- gasoline
ListerHRW3water
yow ling
« Reply #2 on: July 19, 2011, 07:14:12 PM »
Hi Startomatic,
Yow Ling is almost Asian, actually its stolen from the Scott motorcycle " the yowling two stroke". I live down in New Zealand
The engine rating plate is blank, Ill take some pictures tonight and try to post them
thanks
mike
Startomatic
« Reply #3 on: July 22, 2011, 06:41:15 AM »
ok...Yowling 2 stroke. thats new old stuff for me.
this is my resurrected TS 105 with a Yanmar 3 TN70 as counter weight on the 3 wheels trolley. unlike the chang chong chin from China, the Yanmar has no balancing shafts and hence no gear train noise.
i have a high pressure pump awaiting to be coupled this weekend to the TS105.
Andoria S320
ChangChai EV80
JianDong 1115
ListerHRW3water
deeiche
« Reply #4 on: July 22, 2011, 12:31:49 PM »
Hi Startomatic,
SNIP
mike
I have only seen pictures of a Scott, from what I have read they were way ahead of their time.
MikeJohns
« Reply #5 on: January 05, 2012, 09:21:48 AM »
Hello
I have a TS130 which came along with a boat I bought, it's driving a genset.
The engine is ok but before I bought the boat the starter motor was sent off for repairs and pronounced unrepairable and binned.
The owner was subsequently unable to get a replacement.  Hand start is possible but very cramped access and I'd like to get a SM back on the motor.
Apparently it is a belt drive starter. I was wondering if anyone has a parts drawing or a photograph so I have something to go on.   Looking at the setup the starter motor becomes a generator once it's started.
I was given a link to an apparent Chinese copy but only for mass wholesale   http://cfnrj.en.alibaba.com/  I don't know if anyone carries their spares.
deeiche
« Reply #6 on: January 05, 2012, 03:07:14 PM »
SNIP
Have you looked on Aliexpress?  That is the onesy twosy version of Alibaba.
MikeJohns
« Reply #7 on: January 06, 2012, 02:16:18 AM »
Thanks for the tip I'll have a look.
