I know it's been a while, but I wanted to provide a possible fix for those dealing with cast iron cracks.
Arc welding cast iron with high nickel rods is always an option. However, the weld area is always porous, tends to crack outside the weld and often looks horrible. They use this method in India to "fix" new listeroids. Plenty of failed welds!
Brazing cast iron is viable and is my preferred method. However, one must braze the cast iron to steel to form a quality repair. In this case, the crack can be removed by grinding, the area cleaned properly (perfectly), then a steel patch fabricated and located in place with a clamp or screws. Oven preheat the entire assembly and preheat some more with a large torch tip. Then carefully braze the area, using plenty of flux. The brass will adhere to the cast iron and the steel evenly and if done properly, will form a brass "bead" looking like a weld.
The repair must be cooled very slowly. It might be best to insulate the part and let it cool overnight.
If done properly, it will not leak or crack. Plus it will carry plenty of load, if necessary.
