Author Topic: Lister 6/1 restored  (Read 6629 times)
Lister 6/1 restored
« on: June 30, 2011, 03:22:55 AM »
Thought you all would be interested to see the 1938 6/1 completed. This is one of the engines we picked up at George Helmuth's estate auction last October. It would turn over as purchased so nothing could be too wrong inside right?? Ha! it ended up being a mess inside so nothing short of a full overhaul would make it correct.  We are blessed to be able to do the work in house, even the fuel equipment which was handled by my sons. Simply amazing that it sits almost motionless on the cart even though after the video I found it to be runningh close to 700 RPM. Since been slowed down to  proper 650. I hope some day to have another example to work on as I will weigh each and every part so even a listeroid can be made to sit still. The engines does not pound the ground like my Metro, the smoothness just simpoly amazes. The water and fuel tanks are sized to it's intended duty, the engine show circuit.
[youtube]9kSJ56EKZ5s[/youtube]
rleonard
  • Mattoon, Illinois
Re: Lister 6/1 restored
« Reply #1 on: June 30, 2011, 03:57:04 AM »
Butch, you keep raising the bar.  What beautiful work.  If your Lister and the Bamford make it to Oblong, we will have quite the Helmuth showing.  As far as I know, James will be there with us.
Congratulations again.
« Reply #2 on: June 30, 2011, 05:15:32 AM »
What a great job.
Its too bad the Indian manufactures can't see this engine and see what can be done with good attention to detail.  You have reinforced my energy towards encouraging others to pursue the genuine article.  Would you look at the cart - absolutely no detectable motion.
Fabulous!
Casey
contaucreek
« Reply #3 on: July 01, 2011, 01:52:33 AM »
Looks great but my dial up prevents me from running the video  :'(. Please brace that hopper tank. Thats a lot of stress on the engine fittings. Haddock on the SEF had to admit he broke a fitting on his due to the projected weight of his fire extinguisher tank !  George would be proud to see the old iron living on !!
Update July 2 , Watched the vid, sweet runner. You can slow down considerably for show purposes. I slowed my 16 down to 500. Nice cart, I shall now buy the 4 cast wheels I looked at last week !!!
« Last Edit: July 02, 2011, 06:46:56 PM by contaucreek »
« Reply #4 on: July 02, 2011, 06:39:58 PM »
Beautiful job Butch... similar results are possible (with thorough attention to detail) with the clone types as well, looking forward to seeing your other projects put together as well!
listerdiesel
« Reply #5 on: July 03, 2011, 09:24:03 AM »
Nice job indeed, but could I suggest that the water tank needs to be a fair bit higher to get a decent thermo-syphon circulation running?
Peter
