Author Topic: Rubber Pads for Gnerator Mount  (Read 15914 times)
Dave
« on: April 12, 2011, 12:17:34 AM »
I had cut some rubber pads out of a welcome mat for the generator mount that are about 1/4" thick. It's still shakes the barn pretty bad. I have read most people use 1" thick pads.
Does anybody know where I can get pads 1" thick that won't compress with the weight of a 24/2 with gen head?
I am guessing it's about 2200lbs.
Dave
Horsepoor
  • West Palm Beach, Florida
Re: Rubber Pads for Gnerator Mount
« Reply #1 on: April 12, 2011, 06:02:37 AM »
Layers of half inch thick horse barn stall mats. Cut with sawsall or skill saw. Cheap and effective.
Tom
  • Green power is good.
« Reply #2 on: April 12, 2011, 05:50:15 PM »
Shakes the barn? Please don't tell us it's on a wood floor.  :police:
Tom
Dave
« Reply #3 on: April 12, 2011, 10:38:55 PM »
I call it a barn. It's actually a work shop with a concrete floor and cinder block walls.
I have a tractor supply not too far from here. I will look there for the stall mats.
lionspaw
  • SAME ENGINE BUILT FOR OVER 50 YEARS, IT WAS DONE RIGHT!
« Reply #4 on: April 17, 2011, 03:26:25 AM »
I mounted my Lovson 12/1 on a 3"x3"x1/4" angle frame, welded concrete bolts to the underside of the angle, built a 3'x5'x16" box filled it with concrete, sunk the angle iron with the 8 welded bolts in the concrete flush with the top. This was mounted on top of a 1/2" rubber horse pad, 4'x6' i think. I can put a glass of water on top of the engine and leave it there all day. There is NO ground bounce or transfer of sound thru the concrete. anyone interested, i can send pictures and a better description. it did make a big difference. hope this helps.......
LOVSON 12/1, TS 5.0 Generator
Combustor
  • Combustor
« Reply #5 on: April 17, 2011, 01:09:59 PM »
Lionspaw has done first what a lot of people ended up doing, and mounted his whole unit on plenty of mass, as R. A. Lister recommended over 70 years ago. If your motor and base,gen etc, are floating then all attached ancillaries need to be mounted remotely on flexible connections or engine movement/vibration will flog them loose and cause much expensive grief. Not many alternators will survive vibration for more than a short time. Perhaps OK for short term standby runs, but not a long term solution,
        Regards,  Combustor.
Apogee
« Reply #6 on: April 17, 2011, 05:34:54 PM »
Lionspaw,
I'd be great if you posted pics and more details if possible.
Sounds like a nice system.
Thanks,
Steve
Ratman
« Reply #7 on: April 18, 2011, 01:20:39 PM »
Lionspaw,
Thanks,
Steve
I'd like to see some pictures too please. Thanks. Rob  :)
I like to think the older I get the wiser I become, but I'm not so sure.
Roark
« Reply #8 on: April 19, 2011, 02:50:57 PM »
Add my vote to the "pictures please" ticket!
I'm looking at doing something similar and would love to see what has worked for others.
Roark
What?!? No engine parts at the dinner table?  C'mon, Hon...
cgwymp
« Reply #9 on: April 20, 2011, 02:10:23 AM »
I've been waiting to use this....
Listeroid 8/1
needenginerunnin
  • interested in state of the ARK technology.
« Reply #10 on: April 20, 2011, 03:56:16 AM »
morning
add me to the list, thinking of doing the same.
pictures pretty please ;D
needenginerunnin
1949 6/1 electric smooth flywheels & ST 7.5, som base x3, cast indoor silencer X2.
1950's 6/1 som x2, spoked 6/1, LD1 som.
listerpetter LV2, PH1,LD1,SR1, PAZ1, AA1, LT1, AC1. 3.5hp yan clone.
politician's are like nappies, they need changing for the same reason.
take the pi$$ , full of sh#t.
Chaz
« Reply #11 on: April 23, 2011, 10:06:56 PM »
Add me to the list.........
1950 Lister CS 3 1/2 - 1
camillitech
    • life at the end of the road
« Reply #12 on: August 29, 2011, 05:45:15 PM »
Apart from the rubber mat that's exactly how I did my first SR1
Then a man who's been installing Lister's since Adam was a lad showed me an easier way  ;D The danger with this method being that you really have to be spot on with your measurements. What the Lister chap does is to cast the base (1 ton for a single and 2 ton for a twin/triple) with 2" plastic soil pipe where the mounting bolts go. Then before the concrete cures remove the 6 pipes, when it has cured you drop long M12 studs down the holes with nuts and washers on or even just bent at the ends. The you position 'Mr Lister' onto the studs, put the nuts on loosely and pour in a cement grout.
This is my ST2 running with a coin on the rocker box, a rubber mat really is not required, as has been pointed out the secret is in the mass as RA Lister recommended.
I have done at least four SR and ST2s this way, long term any flexibility will work harden your copper wires, internal fuel lines and break your exhausts.
Cheers, Paul
http://lifeattheendoftheroad.wordpress.com/
HR2 Lister 12Kw
ST2 Lister 7Kw
SR2 Lister 6Kw
SR1 Lister 3Kw
« Reply #13 on: August 29, 2011, 07:23:53 PM »
Solid mounting is indeed preferred for stationary installations... rubber mounts became the norm for portable sets where one has to isolate and tame some of the vibration but cannot cart around an extra ton or more of concrete mass.
bschwartz
« Reply #14 on: August 29, 2011, 11:26:47 PM »
I would expect an ST2  to run as smooth as silk in that configuration.  My 6/1 listeroid a 650 RPM however is a different story.
Two cylinder 1800 vs. one cylinder 650 = no contest.
It doesn't jump, but 1 cubic yard of concrete on a stall mat, and you can still feel thumping in the ground.
-Brett
